Hi f150tilt Bill did rebuild the carb when he had the engine. I think the problem is in the adjusting screws, or the seats. It is like the adjustments are not the same after cool down. After cool down it will not start with out starting fluid. Cold full choke no start 1 shot starting fluid pull and start. Then you need to adjust to make it run. I am going to read through what Loren sent me. I think in the long run I will be using the slanted intake and a bowl type carb. Thanks for any help or thoughts, Matt
