Oops.... This was sposed to be a Neck quote answer :laugh:
It doesn't (WHEN you're going slow) ... When first gear is pulled against, it locks, like they said... THEN you take off in first, building speed, until the JACKSHAFT gets up to speed, in which case the CLUTCH on the jack shaft tightens up.. THEN you're engine is driving the drum, but the clutch guts inside are to running speed, so it is tight.. so the power goes from the engine to the drum, to the guts, to the jackshaft.. And you are in second gear.. With first spinning away a zillion miles per hour... Second will chatter until it hooks up... And every time it TRYS to catch, it takes presure off from first, then lets go again because it can't just INSTANTLY go from 7 to 30 miles per hour... SO first catches again....
So on and so forth for a few seconds until she finally HOOKS and actually goes.. I found it actually works a LOT LOT smoother if you lube the shoes in second gear clutch to PROMOTE slipping, until it makes a final lock..
The two speeds are rough as hell on them selves.. Thats why %99 of them ever installed, are welded one speed, and the chain guard is long since lost.. :laugh:
