yes, well they are supposed to :laugh: Look under the bottom spring cup and you will see that there are slots for a sort of spanner wrench to grab, It is a plastic piece (what holds and stops the inner shaft). In a perfect world it unscrews from the bottom section. If you cant get a good grab on it take a caulking gun and use it to depress the spring.
If it s a really rusty crusty shock you may want to check if Blackwidow still has the repro plastic sections in case they break or get torn up before you start messing with them :wink:
here is the "bushing" that unscrews from the lower:
