I have a couple of Sachs recoils for my Arctic Cats. One is original and working, the other has been pieced together thanks to eBay. The one from eBay is missing the pads as well as the small steel support blocks that provide a wider surface for the pads to bond to.
There have been other threads here that mention this rare recoil and its tendency for the pads to break off, thus the shortage of recoils. I have not found any posts on how to repair these pads. All I know is that you can use JB Weld to bond new material on.
What's throwing me off is that the small steel support blocks highlighted in the picture of my good recoil are missing on the broken one. I don't see any evidence of how they were originally attached, even when looking at my original. It's almost like they were spot welded or induction welded.
Should I fabricate new ones before attaching the pad material? Weld them on? Any tips on shaping the pad material once it's bonded on? Suggestions on finding a small amount of pad material? Do I use JB to build up the support area rather than adding steel?
I know I can pay to have this repaired but like a lot of people on this site, I get a lot of satisfaction fixing stuff myself if I can.
Is there anyone out there who has done this or had one done? Thanks!
Here's my good one:
Here's the dog lever arm I removed from my broken recoil. Note the missing pad AND steel support block that should be on the short edge below the hole in this pic.
Here's my good one:
