On my vintage bike the rear sprocket set-up was" " the sprocket weld onto the rear brake drum.
The sprocket was worn out, so cut it off the drum carefully, now need to decide if I should buy another sprocket and machine hole to fit over the drum and weld again?
Or swap the brakes to the other side of the bike, and weld a drive plate on to the hub, and bolt a sprocket to it, easy to remove any time in the future.
What might be the best way to proceed, and what chain to use #35 60 T or #40/41 chain? thanx O S M
