I'll bet its the bigger of the two sprockets on the jack shaft that is the most trouble. As our jack shafts on minibikes have a simple square key there is no way that it can 100% deal with "reversing" forces. They do OK but it is to be expected that an occasional sprocket will worry back and forth, due to the inevitable slop in the keyway, and loosen the set screw. Two sets work a bit better. But one mechanical cure would be to provide splines in the bores of the sprockets...and that is not cost effective. The "reversing" forces problem is really bad if a person decides to chain two or more Briggs engines together. There will be reversing motion in the simple keyed sprockets that will result in relatively short service life until catastrophic failure. But we can live with the low incidence of problems with the less stressed jack shaft sprockets.
