I don't think you can buy the TR-1 Tach from Nautamatic any more.
The look just like the one pictured above but have only an hour meter and RPm display function.
Check ebay maybe some there.....
I like these because they were free ( distributor gave them away like Candy years back ).
And you can pop the back off and replace the battery.
In any even they all probably come from the same Chinese factory
northern has one by sendec and its a tac and hour meter. i have it on my baja warrior and its only one wire wrapped around the sparkplug wire and thats it. its digital and i got it for under $40. only down side is that batteries are not replaceable but they should last the life of the engine and the read out is a second delayed but it works either way.
i found analog rev meter that can be hooked to clone because it uses inductive pick-up. price is pretty high but i will buy one if i dont find cheaper one.
I like the cheap analog tach from ebay. Drawbacks are needle is a little slow but not as slow as the sendtach, and there is no tattle tale. (the digital ones do have that feature) but you cant beat the price and they look nice.
