So I tried cleaning the carb on my Manco thunderbird yesterday. It ran about five years ago. I parked it in my storage building and next spring it wouldn't idle but would run at part and full throttle. Like the idle jet had gummed up over the winter. E10 perhaps?
It's got a 3.5 hp Tecumseh power sport engine. It's got this weird throttle mechanism which is hooked to the governor (so to speak), then a small rod that goes to the throttle plate on the carb.
I took all the jets and float valve out and soaked them in Seafoam, blew them with spray carb cleaner and blew them out with compressed air so they should be cleaned out. But the bike still doesn't run right.
Symptoms:
Leaks fuel when engine is not running (tells me either the float level is out of adjustment or seat is eaten up)
Won't run unless choke is set halfway. Seems contrary to the above, wouldn't this mean the carb is running too lean?
Runaway throttle. When I briefly road the bike it almost ran out of control so I killed it.
I've already rebuilt the carb once so I'm thinking I just need to start with a new carb.
I've got several in my watch list on Ebay for around $15. They all look the same but have different part numbers.
I read the sticky on Tecumseh carbs on this website but the carb I have just has the number "42" stamped on the side. Not a 6 or 8 digit number as per the sticky or the ones on Ebay.
If my carb looks like the ones on Ebay, is there any reason I can't use it? As long as it's for a 3.5 hp Tecumseh engine and has an independent choke, will it work on my bike?
Also can I do away with this funky throttle setup and tie the throttle cable directly to the throttle? I suppose I would need to leave the rod that connects the governor to the throttle plate. Thanks!
Symptoms:
