The rod I tried is a rod specific to the HS engines, not the OHV one with the dipper in the wrong spot, It was hitting the case I think even with the bolt out IIRC.
One of these rods:
Thats in a late model 80's H35 sidepopper I have, which came with large journal crank and HS rod factory (but still has the equal sized valves unlike the really late models where they shrunk the exhaust valve down).
If you compare an H engine and an HS you can see they added a little hump in the case on the HS, On the later H engine the hump still is not there. But the the stock HS style rod does clear, but not enough for the aftermarket rod. They may have altered that section slightly to give enough space on the later version but its not very noticeable if they did, I can't test an HS rod in the early small journal engine blocks due to not being able to get a crankshaft in there with the right size journal. So if you were going to go as far as boring out the flywheel side journal and use a larger journal sidecover on an early engine you may have a slight clearence problem at the face even with a stock rod to contend with as well.
And yes the one example Billet rod I was referring to was the one in that engine Karl had. that one was in an oil pump engine, so no dipper and had actual bearings, heres what the standard oil slinger looked like that Ron's used for the small frame H engines:
