What is the length, thread size per inch, hex head wrench size, of the doodle bug 2.8HP engine? SAE-Metric? How long? What size wrench? Stock size?
3/8"-5/8"-3/4"
3/8"-5/8"-3/4"
Metric thread pitch isn't measured in TPI. The distance in MMs from the point of one thread to the point of the next is the pitch. They're most likely 8 X 1.0 or 8 X 1.5 threads. Not sure on the length, but that would be measured in MMs also. 1" = 25.4 MM.
if you got a drill gauge .
your bolt will fit in the 5/16 hole
and the mm size for that would be 7.937 with your 12mm head
or change it to a different type head.
motorcycle shop or hardware store will help you out.
the mm length is more then likely 24.606 just under an ''
mine are stock 12mm hex head .
i have two of the mini bikes .
with the 2.8 motors.
i removed one motor a few day ago
and that is what i took off it .
hadnt had time to check the other one out .
maybe its got a 10 mm head.
then again someone might have
tapd new threads and used different bolts.
no big deal as long as the threads are correct.
go with it.
