The rear sprocket just will not line up with the clutch. I purchased a 60t #35 sprocket from GoKartGalaxy and drilled the holes to fit the pocket bike wheel. Now,the axles are only 10mm instead of 5/8",so you need bushings to make up the space. The axle holes in the rear of the Grand Prix frame are oval,so that may be a factor in alignment. When you install the bushings,you have to have 10mm spacers as well. I am considering putting the wheel into a frame with a regular 5/8" round hole,just to see if that is the problem. I am also wondering if the sprocket is,actually,a #35. What are the measurements between teeth of a #35 sprocket? It's close,but it just keeps spitting off the chain. Thanks for any advice.
