I have a Bird Wren frame and the space between the axle tabs is approx. 5 3/8" and the tab is drilled out to 5/8" for the axle. What would be the maximum size wheel/tire/sprocket size I can use and to replace the scuff brake would I be better with a band style or disc style brake? I'm also a little confused to whether I should use a 5" or 6" wheel and tire combo, I'm 250 lbs. so I'm thinking bigger is better...
