I'm new to mini-bikes and I took the baja through some pretty deep wet mud yesterday and the rear tends to kick out a lot. The tires are old and probably need to be changed.
Any suggestions on a good tire for mud?? Would moving up a tire size help any?? Where I hunt the ground is very soft so need something that will really dig through the rough stuff.
Also as far as front tires go, do you want them to match the rear, or can you pretty much use whatever you want on the front since it is not the drive tire.
