I can see the front and rear light brackets. Your motor is a real keeper if the lighting coil is intact. Most parts for these motors are still available. 6hp, 7hp and 8hp briggs all are the same outside dimensions. 90 percent of the parts are interchangeable including the tin, recoil/fan shroud and carb parts. Tote gotes came with a 'climbaway' clutch that the Bonham Corp built. They aren't easy to find an usually cost as much as a new aftermarket clutch. A comet series 40 (or a GTC40) will work.
