I have a HS50 I just finished building for a 67 rupp continental I am building. I would like to replace the thick blower housing with the thin one. I had already replaced the original flywheel with the earlier lighted magneto/aluminum flywheel and just received a thin shroud. First off I did not realize the difference in thickness and also the width on the thin shroud is about .5 inch thinner across the middle. First attempt at fitting it I see it does not fit over the motors current tin that the thick shroud fits over, so my first question is do I need different tins to mount the shroud to? Also being thinner is there a different starter cup for the thin shroud engines? Thanks for any help you guys can provide me.
