Hi all. I'm still having problems with this engine of mine. Now it likes to entirely bog down and cut power when I hit about 4k and it sputters at that rpm until I let off and decelerate. If I start from a stand still the engine revs perfectly and sounds excellent until then. The plug reads a light tan so I'm doubting the mixture. I'm thinking possibly to clean the carb? What should I look to clean besides the jets? Could this be anything else besides the carb? Running 93 octane.
gx200 + arc rod, 18lb springs, flat top piston, milled .010", ported, 8deg flywheel advance, straight pipe, unifilter, stock carb (.036" main jet), gov removed.
