Ok I have decided pretty much that I'm gonna set my bike up with a TAV2 but in order to get the diven to clear the frame I'll have to tilt the engine up at the rear, just some rough guessing I'm looking at 10, maybe 15 degrees at the most..... I've seen kart mounts at 15 degrees but is there anything special that needs to be done to assure proper oiling?? just a little extra oil in the crankcase I'm assuming??
The engine is built fairly stout (.080 milled and ported head, flat top, .010 head gasket, SS valves, 26lb springs, locks, retainers, ARC rod with built in oil scoop, ARC billet flywheel, 285 lift, 250 duration cam, 6 degree key, chromolly push rods, 24mm mikuni flatslide)
I know the tav2 is rated to 8hp which will be under the output of this engine but since it's gonna be mostly a rider and not strictly a drag bike I figured I'd give the tav a shot, worse case senerio it burns the belt and if so I can pull it off and go with a different clutch... If I set the engine plate up flat I can't go from a bell or disc clutch to the tav but I can go back the other way with the mount angled..
