when I was kid, the throttle on my Fox Thunderbolt went. and there was no internet, no minibike shops around so I had to do what i had to. I actually tied a shoestring to the throttle plate and kinda ran it up the frame, then up the right handlbar. then tie it off where the throttle would be. I used my thumb as a throttle. It took some time to get used to, but it worked eventually. You could try it, just until you get your parts. maybe you could use a small paper clip on the throttle plate, then wrap the string around the clip? as far as the adjusting screws, screw the one on the bottom all the way in. then turn it out 1.5 times. the one on the side do the same thing but turn it out only maybe one turn. when you pull the rope, you should be giving it gas at the same time...it's gonna be hard without a throttle, so try the string, it can't hurt. you might actually get it running. when you do, you have to play with the screws on the carb. start with the one on the left and if it starts, let it warm up for a minute or so....then keep turning it out until it's just about ready to stall....then turn it back in a tiny bit.. do the same with the bottom screw. turn it in, then turn it back out when it just about stalls out. good luck!
