Planning to swap one of my 196cc Baha engine with a 212cc Predator. Will I have to change the clutch, or will the old one fit? Anything else I need to worry about? Thanks.
Okay great thanks for the info. So to be clear before I order this, the clone's clutch will slide right onto the shaft coming out of the predator? Thanks again for the info!
The lighting coil and flywheel from a 196 will not swap without extensive work. If you have a hemi predator, you need a Kohler 270 lighted flywheel for the correct taper on the crank.
Sent from my Texas Instruments Speak and Spell...[emoji2]
