I bought a 81 Sears Green Streak from a swap meet to build to a customers specs.
The bike came with the original Tecumseh 4hp HS40 on it.
It had spark and compression and would run if some gas was dribbled in the cylinder but the carb wouldn't let fuel in.
I installed a diaphragm carb from a...
The KOL they made the Mickey bike from for sale on Tulsa Oklahoma CL $125 and looks solid. I'm not going to even call on it because I'm done buying and have no desire to have to ship it when I sold it. Has a turd of a 3.5 briggs but that's easy to remedy. I hope someone can get it and no I wont...
Looks to have the original white Tec with side fill tank and the seller says it starts and runs easily, only $125. I'm not buying any more for a while because I'm considering moving back to a rural area and will have to find storage for tons of stuff as it is. Someone can post a link if they want.
I have what I believe to be a Sensation Mike Bike. I'm asking $125. I live in Sacramento, CA
The last picture shows where there was a frame break that was re-welded and reinforced. (I did not see the original break, nor did I weld that)
Edit: Runs, but will need a throttle cable. Bike...
Baja roller, 22x11x8 Kenda rear tire with tube! Good front tire. Sealed bearings are fine. Brake pads are good. Previous owner did the paint.
Arizona bike, so no rust.
$125. As is sale. Pick it up at MacFest or Funday#3. PM me if you want to lay claim.
Bullhead
I bought this orange bike with total intentions of parting it out. It has some VERY nice kinda hard to find parts.. Speedo, headlight, shocks, wheels, Carb with cables.. small parts... a Buddy begged me to sell it to him so he could try to get it running.. The bike MUST need rings and crank...
