Hey everyone,
I ordered a bunch of parts from OldMiniBikes this week and got the wrong drum/sprocket. Seems that they don't sell a 5" with flange although they have the drum (no flange) and the 5" brake itself. If it helps I got a new Azusa 6" Tri-Star wheel with the order, so that's what I need to...
I was wondering where I could get the flange to make a custom exhaust. I have extra pipes laying around, but without the flange, I can't do anything with them. Is there a place where they sell them?
Need 1" custom bent Predator header, underseat style like OldMiniBikes but more compact, shorter, flange welded, etc. contact me for details and quote. Thx, JB
On some the later 3.5hp style engines they have a flange convertor that screws into the 1/2 pipe thead on the exhaust and sticks out just a touch with a standard 2 bolt flange for bolting on the bigger muffs that cant unscrew with the tank on.
Anyone have a part number for that or a stock...
Set of four Wagner flange bearings. 1 3/8" OD 5/8" ID. BRAND NEW OLD STOCK from the 70's. Made in the USA!! Very similar to the type used in Cat and Bonanza minibikes.
Will be shipped DRY, like this unless specified:
Or I can pack them with some good quality grease...
Hi everybody I am looking for a exhaust flange for a 1969 HS40. I need it to weld the original exhaust back on the Fox Street Scamp. Thanks for any help.:thumbsup:
Hi everyone I need a exhaust flange to weld my exhaust on to. The flange needs to fit a 1969 HS40. OldMiniBikes warehouse has full exhaust not just a flange. I may have to buy the full exhaust and cut off the flange. :thumbsup:
ive got a honda 13 hp clone off a genny, swapped the crank for a straight shaft to put on my John Deere AMT. didnt come with an exhaust so i need a flange, does OldMiniBikes sell one? i saw a few different things on there but mostly looked like smaller clone stuff. i need to order some from OldMiniBikes anyway so...
Picked up a nice Tecumseh 5HP H50 XL (steel liner, ball bearing) engine but it is just the base long block. I have all the remaining parts to build a full engine, except for this carb mount flange thingy.
Anyone have a spare one? Let me know if you do and what you need for it, I have PreyPal...
I took my carb apart on my Baja DB30 for a thorough cleaning and lost the hex flange bolt that holds the cup to the carb. Can anybody give me a part number or size so I can go to the store and get a replacement? With the seal. Same as in pic next to drain screw. Thanks
[/URL][/IMG]
I would like to replace the bearings in my Sensation mini bike. The rims take flanged bearings, 1 3/8" x 5/8" x 7/16". Overall diameter is 1 1/2" including the flange.
It looks like there is nothing inside the rim to hold the bearing in place, so the bearing needs a flange.
I cannot find...
I have here a NOS Taylor model 200 muffler with the angled tip. This is the polished version. It has never been mounted on an engine , but has been stored and moved here and there etc so trivial marks I'm sure here or there. I've never seen a fresh one off the line , but I'm sure they did not...
Does anybody on here make an exhaust flange with a short piece of pipe for making your own header? My motor has both the flange bolt holes and the thread in pipe options. I would like to make a header and go with the flange style for the but either need to find an old donor exhaust or someone...
Does any body know the diameter, thread, and length of the bolts used to secure the exhaust pipe flange to the head?:confused: Also, any advantage/disadvantage to using typical "hex" head vs. "allen" head bolts in this application?:confused:
Thank you:scooter:
