setup
  1. 4
    Throttle setup for clones?
    I've set up two of these things with the Northern Tool twist throttles, and the cable last about 2 weeks... Is there a trick? I've had nice large radius curves to the cable and they get hung up and stop working.
  2. maddcarson
    should we setup a race like this??
    This would be baddass if we setup a race like this. I wanna know if we can, should, and how would we setup a race like this to happen. YouTube - sfvisbf 3
  3. Erok000
    DB stock throttle setup
    So since ive noticed that my throttle assembly wasnt put together right before I got it:shrug:, I have adjusted a spring and what not. I have noticed a great deal of improvement, but Istill dont think it is right. Can someone show me a few pics of how the throttle line ties into everything. I...
  4. throtle setup
    throtle setup
    the throtle setup that i have on my manco tunderbird
  5. D
    b&s 5hp motor setup
    Hey guys, I recently came across a lawn mower that my dad was throwing out and I noticed the motor was still working when I went to pull start it. Anyways, long story short, I want to put this thing into my "cateye" style pocket bike. I disassembled the bike down to the bare frame and the motor...
  6. L
    Help with throttle setup for B&S 3.5 hp
    I just picked up a go kart with a briggs & Stratton 3.5 hp engine. The throttle spring was not hooked up and I can't see where it should be hooked to. I attached a pic of the direction I think it should go but any ideas where to hook it to? I tried finding a diagram of this but couldn't...
  7. sundries
    Question about DB30 brake setup - how to put back together..
    I took my brakes off the db30 and opened them up to remove old pads and then this v shaped pin is there and i don't know how it goes back in. I'm not new to the db30 itself , but new to replacing pads and would appreciate any advice or arrows pointing to other threads about this. here's a...
  8. P
    speed calc for jackshaft setup nedd HELP please
    i have a vary big minibike for me to ride it has a 6.5 clone motor jack shaft no gears yet need someone to help figure it out what gears to get tires 21 inch clutch 12 tooth drive sproket 72 tooth i really need the gearing on the jackshaft for the best performance pull and top speed thanks...
  9. minibburna
    db30 rear wheel setup
    Im looking for the rear wheel setup for a good ole db30 i need the hub, brake disc or rotor, and sprocket if its got a tire on it thats cool too ive tried getting it from baja....back order until november called some of their dealers...back order until the end of the month id like...
  10. isaacson06
    how many rpms will my setup turn
    Blue clone Gov removed 18lb valve springs custom header I made 90 jet Air filter Just wanting to know whatt it will turn so I can put it in the gear calculater. Thanks
  11. H
    Over-complicated throttle setup on H70-130000
    Hi all, I just put the engine back in my Retek Cheetah 250 that I'm rebuilding. I'm not happy with the throttle setup, to say the least. I don't like how I had to route the cable, it seems to bind a little, and the mess of levers, bars, and springs mounted to the engine seems ridiculous...
  12. minibikemonster
    I need a brake setup for my DB!
    I live in Visalia Ca. and need a solution for my warped brake rotor. If you live around here and are selling parts please let me know.
  13. G
    Point Setup
    Hey i'm seting up points on a 5hp and i was wandering if there has to be a space between the condenser and movable point for it to work. If so how much?
  14. S
    Throttle setup
    My buddy doesnt want to spring for a kit for his 6.5 HF hound motor. Also he does not want to bypass or remove the governer. Anyone have info\pictures of how to set up a throttle? right now out of the box the governer wont allow acceleration at all any adjustment tips? Maybe photos or a video...
  15. M
    Differential setup for an Alsport...
    Hello all, Recently found an Alsport Trike but it's setup w/ a live axle... not so good for the corners and i want to street it a bit... what/where can i get a differential setup for it? I have the skills/means to do some modifications to the axle setup so even if it's a bit tricky, any...
  16. 8
    6.5 throttle setup and install questions
    Ok, please dont kill me for bringing this up. I will be getting my clone tomorrow and putting it in my db30. I want to know what the best throttle linkage method is, because i have seen quite a few. Also, what else should i expect when putting this in the DB? I got the mounting plate so it...
  17. maddcarson
    does anybody have pictures of the stock throttle setup
    i need pictures of the stock throttle setup cause i tried to mod it myself and it only goes slower
  18. X
    kill switch setup
    Ok, so I can generally figure out mechanical stuff, but I really struggle with electricity. I have the oil sensor removed from the inside of my clone, but never disconnected the external wire. I have a toggle switcht type kill switch mounted to my handlebars. I still have the original...
  19. R
    Drive setup
    ok this might be a stupid question but....... i dunno whats a good easy way to connect a sprocket to the rear wheel...:doah: can sumone plz show me some of there setups and how they do it?? also im gona be making a mini with a live axle using some pillow bearings and i need help doing...
  20. mybiz
    Needing Info NOS McColluch carb setup
    Can anyone give me the proper names of each part have the carb and the parts have no numbers on them 2 peices I know have the brand names on the one is the Vantec reed cage what is it called a "V6 cage"?? Next how do i ID the carb make/model?? I'm thinking of selling each part separate but i...
