tank?
  1. J
    Tote Gote tank?
    Anybody got a line on a tote gote gas tank? :thumbsup:
  2. Strigoi
    Beginning of a cylinder tank?
    This was part of the a/c system on my Firebird. I was going to scrap it but then thought it could be used to make a cylinder gas tank. It does have pipes running inside of it and you'd probably want to get rid of the part with the fittings anyway. Figured I'd throw it up here for free if...
  3. markus
    getting paint off a plastic tank?
    If got a Tec tank I want to use, its got some spraypaint on it here and there any tips on what I can use to get it off with minimal to no scratching or damage to the plastic? It has some fade on the other side of it so I plan to use "forever black" like I did on another tank I had...
  4. 5horsebriggs
    whats the best way to clean out a gas tank?
    Well im getting a new briggs carb thanks to trailbronc, but before i put a new working carb on my engine, i wanna clean the tank, whats the best but easiest way? Omg sorry bout the tiltle
  5. ozark caveman
    Rusty Gas Tank? Can I Save It?
    Guy's I just got totally ripped off on e-bay. This guy sold me a very rusty gas tank. The outside is fine but the inside is rusty. What can I do?
  6. C
    OK to drill and tap Tecumseh plastic fuel tank?
    Anyone ever drill and tap Tecumseh plastic fuel tank to install shut off valve? Seems like it should work OK, especially with a threaded nylon fuel valve like this: Cutoff Valve w/ Filter - replaces Tecumseh 1/4". This would solve the problem of installing shut-off valve and filter in a...
  7. Bassicly LouDog
    Roper Gas Tank?
    Does anyone need a Gas tank for resto? I'm about to turn it into a battery cover for my lights, but it's original Roper so if someone needs it let me know. I'm in no hurry to chop it. it's cosmetic. Still need a place for switches and such.
  8. murrayTR2
    How do I remove gas tank from predator engine?
    I would like to remove the gas tank from my predator engine and add a custom one to the frame. How would I do this? I cant figure out how to remove the gas line from the carb
  9. cpu77
    Anyone make their own gas tank?
    Anyone ever make thier own gas tank out of 3 or 4" metal pipe? Any pointers?
  10. balljoint
    Possible Fuel Tank?
    Custom chopper round oil tank kit harley triumph bobber | eBay Might make a nice custom fuel tank:blink:
  11. mmisterbungl
    Painting a plastic gas tank?
    Wise, not so wise? What kind of prep should be done, assuming lots of gas is probably embedded in the plastic? What KIND of paint is best to use? I'm sure that some paint, if not all would run immediately upon contact with gas. Any thoughts, opinions, no no's, pros cons?
  12. T
    naval jelly to clean inside of tank?
    hey guys, I have my briggs and stratton tank and the inside is super clean, it's only rusty on the reserve pick up for the carb, my motors freshly rebuilt so I don't want to suck up any c:censure:p. can i use naval jelly to get the rust out of the reserve? or does any one else have any better...
  13. 1
    Gas Tank?
    Whats everyone do for a different gas tank for the clones? mine is starting to break from vibrations on the back mounting hole.
  14. minibikes4life
    pulsa jet carb/without the tank?
    i had remember hearing about this a while back, that somebody had setup there pulsa jet carb on a 5hp briggs, to work without it being mounted on the gas tank. im curious about trying it, i know there's no point in doing it, but im interested in trying something different. anyone got any...
  15. Tom S.
    Need a Gas Tank?
    This isn't mine. I just saw it on ebay and guys here seem to ask about these pretty often. Not much time left on this one. It would be nice if he'd posted a pic of the cap and or pointed the camera inside. I've got a Continental engine with a tank that's not quite this nice. I was tempted to bid...
  16. W
    Triangular tank?
    Hi everyone, I have an odd one but first, let me say that I don't have a bike at the moment. I restored an old Honda Z50 with my son a number of years ago and that was a lot of fun. In fact, the reason for my post is to see if I can find another bike that I saw when I was a kid back in the...
  17. oldyeller
    6.5 clone with too tall tank?
    I am planning on doing a 6.5 clone swap into our dirt bug...After doing some reading on here I ran across a post saying something about some of the clone engines having a gas tank that is too tall to fit?...Anyone have a pic of this tank setup so I know what to stay away from?
  18. K
    found a mini bike had duck sticker on tank?
    what is it is is rare ? needs a little resto like paint but its 100% original lmk any info i can get ill post photos in the am its dark out
  19. OldMinibiker
    How Many Miles On A Tank?
    Any of you know about how many miles(the range) you can go on a full tank of gas with the HF 6.5 clone?(Of course it's going to vary) I have a bicycle pusher that uses the clone engine and am just curious how far I can get before refill. So far I've passed 2 cops with no problems.Hopefully it...
  20. dopowa
    Will this work as a tank?
    The bike is on hold until I get the Wheelhorse running and the engine swap in the Omni, but I found something out at my parents that might work as a tank. Its off of an old stove, really old. http://h1.ripway.com/dopowa78/pics/HPIM0465.JPG http://h1.ripway.com/dopowa78/pics/HPIM0467.JPG...
