Looking for some help from the Briggs "gurus" out there...
I have a '81 B & S 3HP Horizontal engine with a "Pulsa-Jet" carb.
Model: 80202
Type: 0855 01
Code: 81010703
Background:
I picked this engine up several weeks ago non-running. It had no spark but had good compression. A couple of days ago I cleaned the points, 2 leg armature, and re-gaped everything to B & S specs. Then I had spark! I purchased a new spark plug to B & S specs, new diaphragm, needle and seat kit, and gaskets. Carb was removed and cleaned thoroughly with carb cleaner including the fuel pipe screens. Next, I cleaned the tank of most rust using the "metal BB" method.
Note: The previous owner removed the governor from the engine.
Today I went to reassemble everything and do a test run. The engine runs without the choke and throttle set to at least half way. If I let go of the throttle the engine dies. The idling screw is closed almost all the way for most RPM. However, the engine still doesn't seem to be reaching its fully designed RPM with the throttle opened all the way.
What could be limiting my engines RPM and not permitting it to idle without the throttle half way open?
Any help would be appreciated!
Model: 80202
Type: 0855 01
Code: 81010703
Background:
