Miked, Sometimes, if the motor is put away with fuel in it, as the fuel evaporates, over a long period of time, it coates the pick-up tube with a film, inside and out, a good carb cleaner, will liquidfy it again, and a blowing out with compressed air, will remove it, pay good attention to the little screen on the bottom of the tube, get it a time or 2 with the carb cleaner, and then with the air, on some styles you have to be real carefull that you have all the small parts out, cause when you hit it with the air, small parts fly..., also check to see it the head bolts are tight, compression starts in the cylendar, and if the head isn't tight, or the carb gasket is leaking, compression is lost, good luck .
dave
