The spring that you still have hooked up in your picture is the return spring-the other end hooks to the bottom side of the muffler's wire heat guard. The medium spring is the one in this picture:
The hook that is more than 180 degrees goes to the right, the hook that's just 180 degrees the governor shaft (left) the open ends of the hooks face the motor.
The little spring should be wrapped around the carb linkage is it still?
If so linkage in the big hole of the carb throttle arm-spring in the little hole---other side of linkage in top hole of governor arm, spring in second hole. The linkage should go down the hole in the carb arm and go from outside to motor side on the governor arm.
The armbone is connected to the wristbone-the wristbone is connected to the handbone-the handbone is wrapped around the just plain bone--now hear the word of the lord.
