I don't know if anyone has done this when grinding valves in a flathead engine but it works great... Take an old lifter from any flathead or ohv engine, clean the head of it with acetone or rubbing alcohol, clean the valve head from any carbon and wipe clean also... Now take some quick set epoxy, mix a small amount of epoxy and coat the head of the valve while in the block or a vise, gently set the lifter on the valve (head to head), let the epoxy set about an hour, chuck the lifter in a cordless drill, slip the valve in the block with some oil on the shaft, apply some valve grinding compound to the seat and using the drill on slow grind the valve applying fresh compound as you hear the grinding noise getting quieter, periodically check both seats until both the block and valve have a nice grey seat.... This works much better than one of those handheld suction cup lappers and NO blisters LOL..
I also use a cordless drill when doing OHV heads..
when done grinding the valve sin teh flatheads just pop the valve and lifter apart, take a putty knife or a carpenter knife to scrape the glue off... it will peel off pretty easy...
