hi guys, for those who fabricate their own axle tubes and hubs, what size tube are you using in order to slip a standard 5/8 bearing 1 3/8 OD? I was wondering if I use this "1-5/8 OD x .120 wall x 1.385 ID" if there would be too much slop for the bearing.
I am trying to avoid using a live axle setup if I can weld a hub with 4 hole on 4 inch pattern to tube with bearing that I can weld my sprocket on. the standard hubs that you find on the websites do not allow a wide tire fit which is why I am trying to extend the tube. thanks.
