You will have to use a straight edge and feeler guages to check to see if the block is warped...The head you can run over a flat surface like the top of a steel table saw or a thick piece of flat glass with some sandpaper on the surface...or a nice flat piece of sandstone...This will show high and low spots...
Chances are the gasket just deteriorated over time and was seeping, very common and useually doesn't result in any warpage..
I'd spray the block with Purple Power degreaser and scrub it down good, inside and out (I assume your rebuilding it) before any blasting..
I personally blast my blocks also...I'll bolt the head, side cover, valve cover ect on the engine...leave the sparkplug in the head and blast away... Then wash and wash and wash with degreaser again until it's sparkly clean inside... Blow everything out real well with an airhose also...
If you don't get all the grease and gook off and out of the engine the media will stick to it and you'll have more work in the finaly cleaning... I'd also hone it and grind the valves before blasting and cleaning since you'll have residue from both those procedures that will need cleaned out..
