Well found most of the problem a intake leak . When i ported my head intake side got pretty big , the lower edge got kinda thin and also got the surface not flat . Fix , cut a small piece of marble to use as a sanding block and trued up the surface and also did intake and made a new thicker gasket all is good . I still need to epoxy around the outside of the intake port for more surface area for the manifold to seat against . Okay motor still starts a little hard but it also restarts , but is still kinda lean thinking of going to 17.5 pilot jet , but i'am still in middle clip will going down richen it up .
