I picked up some early/first version HS50 engines (1972/1973) in the past couple of weeks, one is just parts and the other is pretty complete, but both are missing the number tags. I am trying to do some cross referencing and trying to find some part numbers which can be tough without some numbers to work with.
Specifically looking for lighted engine numbers with a ball bearing crankshaft if possible (as that is the complete on I have coming)! These will be the little tag most often bolted to the left side small bolt that hold the cylinder air deflector tin to the case (above the sidecover).
Any help really appreciated!!!! I want to try and catalog what I can in differences and cross reference parts etc.. Thank you
