Havasu Dave
tig welder would work the best for this problem?
Havasu Dave maybe a guy could machine out a piece of urenthane with the same round curve as the fender for a spacer. urenthane would help absorb the vibration,but would not move around like rubber would..?
IMO, everything is better with a TIG machine. I don't have one, but I do use .024 on a MIG with gas. Seems to work well for the thin stuff. (On the aircraft, you stop drilled so the crack in the aluminum would stop creeping until such time as you could get the entire panel replaced at a depot-level facility)
Something I was thinking on my fenders- the same as doc is dealing with, except that the fenders are recessed on the sides to fit around the fork uppers. Cutting out the curved mounting area using the bottom tree as a guide, then weld in a flat piece in the same shape.
It would make the chromed fender sit within the newly painted forks as some sort of a nesting, molded design better than original, and would mount more securely. Down side is the fender is no longer original.
Sorry for the diversion here- just something I too am once again dealing with- as the build off deadline ticks away, so does my window of opportunity to do the right fabrication work and still have time for the chrome shop.
