First... Take off the chain... That way it wont run away from you when testing...Make sure the pivot nut is loose. They are tightened at the factory. Then start and adjust. If it is revving up.take the throttle cable off and re adjust it. If the cable is off at the carburetor and it is revving up then there is a linkage issue or the idle is set too high. If it still does it...take pics and post.
