honda g200
I bought a trashed engine today, unseen, for 15$.
All I knew, was that it was a honda.
When I got it i saw it was a Honda G200 197cc.
I bought it for parts, but as I only have gx engines, i doubt any parts ar interchangeble. ?? or ??
Engine seems i god shape, but the conrod is wasted.... does this fit from the gx series?
I can`t find much info on the g series engines, but I can se it is a side ventilated engine and seems like the output shaft is the cam?
so cam an crank is not usable in the gx..
It also has C.D.I ignition, is this something i can use on the gx200 I am working on?
Any thoughts on what i should do?
Motra
No parts are interchangeable. The valve springs are the 18# ones that people install in GX engines, but they're so inexpensive new that it probably isn't worth using old ones. With the camshaft PTO the engine is pretty much useless as a minibike engine. Max camshaft RPM is about 2000 and clutch engagement is usually about 2200 RPM.
