Hi all.
I used to post on here quite a bit a few years back under the username "briggsscooter". I forgot my damn password and no longer have the email account that that user name was linked to. Oh well.
I've surfed the internet and this forum and cannot find info on any manually operated clutches that are commercially available. Why is that? I might be biased from my dirt bike and street bike experience, but i would take a manual clutch over a centrifugal clutch any day of the week. Its surprising to me that this basic technology hasn't carried over to the mini bike and go kart world.
Fast forward a few months and I am 90% complete with designing a manually operated clutch for a horizontal shaft engine. I will be starting the prototyping phase in a few weeks once I get a few minor design details worked out.
Some specs:
-Completely bolt on unit
-Actuated by standard lever and brake cable
-Does not apply a thrust force to the crank shaft bearings
-3.25" diameter
-Needle bearings used throughout
Some bad specs:
-Sprocket center line is farther outboard than a conventional centrifugal clutch by about 3/4" (this is when the centrifugal clutch is mounted such that the sprocket is close to the engine). I can't figure out a way to get around this. This would require shifting the engine by 3/4" to account for it.
-Minimum sprocket size is 15 teeth for #35 chain. I MIGHT be able to get it down to 14 teeth but i doubt it. My thought, though, is that since launch RPM will be higher than a standard setup, this wont be as big of any issue as one might think. Still unfortunate.
What do you guys think? I am trying to gauge interest level to see if this is something i should pursue as a product instead of just building one for my scooter. Price would probably be comparable to a Comet TAV2.
Thanks for the feedback.
Some specs:
-3.25" diameter
Some bad specs:
