I've got an almost new MT centrifigual clutch. Problem is it came off another project that uses a #40 series chain and I need #35.
Question. How do you remove the sprocket and bushing from the clutch casing?
Can I simply order a rebuild kit with new bushing and sprocket for a #35 chain?
If yes, then for added low end power I would go with a smaller drive sprocket say 11 vs. 12 tooth correct?:shrug:
This is a 3/4" bore going onto a tappered shaft.
