I haven't posted in a while because I have been doing some troubleshooting. I have been having a lot of tire wobble. My axle that I bought was 25.4 mm (1") and the bearings I got were 26mm. So I just drilled out a little wider slot with my variable drill and slid them in. The problem with this, is when I drilled the bigger hole, I think the hole I drilled was a little off-center on both sides, causing the wheel to wobble. To fix this, I shaved the bearings down to 25.3mm (dont ask how I shaved down the bearings :wink
. Then I slid the bearings a tad past the bigger slot that I made and spaced them apart with a spacer. I hooked up the wheel with all the axle, spacers, and washers, but it had only improved 50%. I wanted to eliminate the wobble before I enforced the sprocket hub tubes together but since the sprocket was perfectly aligned (centripetally) I went ahead and welded the tubes together. Another problem I had encountered was that I was too lazy and didnt weld a tube to the back of the motor plate. When I ran the motor, the torque amazingly pulled the plate up about a 1/2". So then I pounded it back down, and welded a support beam across the back.
