Some have seen my rant about Drag Parts.
http://www.oldminibikes.com/forum/general-minibike-talk/94383-drag-bike-parts.html
Snowmobile Engine Powered Mini Drag Bike...
Well, I'm working on making it happen !
Here is the Parts List; some I have picked up..
Tach / pot, yes
Heavy Duty Brake Disc 1" X 8" rear, yes
Hydro Brake Master & caliper rear, yes
Front axle 7-1/8" x 15mm, yes
12" X 7" Rear wheel, yes
Steering damper, yes
Handle bar grips, yes
Fuel Tank, yes
Seat, yes
Drive Clutch 1", Yes
Rear axle 1" x 18", Yes
Rear bearing pillow blocks, Yes
Handle bar clamps, Yes
Frame neck bearings, Yes
Rear 1" x 4 on 4" hub, Yes
Forks, being built--------------------
Triple tree, being built--------------
Wheelie Bar, build it-----------------
Roll Cage Corner Gussets, Yes
Kill Switch Suzuki Button, Yes
Indicator Tachometer, Yes
Universal Single Gauge Holder, Yes
Rear tire, Yes
( 22 )
Still need;
Brake Disc(s) front,
Hydro Brake Master & caliper(s) front,
Front wheel,
Front tire,
Handle bar,
Throttle cable assembly,
Petcocks,
Frame & bending,
Twin Throttle cable,
Engine & Carbs,
Engine Clutch ??
Air filters,
Exhaust, flanges, u-bends and cones,
( could go two into one pipe OR twin pipe ? ) twin pipe is better
Rear spoiler ( optional )
Jack Shaft & Gears/ Chain ???????
(14 Left )
JR DRAGSTER PARACHUTE ????????????????????????????????????????$$
:grind:
Tach / pot, yes
Fuel Tank, yes
Seat, yes
Rear tire, Yes
( 22 )
Still need;
Front wheel,
Front tire,
Handle bar,
Petcocks,
Frame & bending,
Engine & Carbs,
Engine Clutch ??
Air filters,
(14 Left )
:grind:
