Mini Drag bike build
bikebudy
Banned - Must pay $500
Yup, yup, :eek:ut:
I'm going with the Stingers /with snuffers.
BUT, will make the snuffers removeable. So when I want to, I can let it loose. :laugh::scooter:
P.s. - Mic carbs are 36mm per cyl
:biggrin:Yes....but sooner or later anything with a twist throttle.....you just got to twist it all tha way and see what happens .:biggrin:
bikebudy
Well, Engine ate the fan bet. so it needs a new one.
Someone painted the engine shrouds & recoil blue, thats gotta go, lol
CDI is messed up and needs replaced, most of the time its only getting spark to one cyl. Found out the connectors in the rubber plug are broken. I tried to solder them with no luck, high engine RPM brakes them again.
Clutch is messed up and needs replaced, I hope with a Comet 102 OR 108.
Good news is the cyls have 120psi compression on each side and when it has spark on two sides, it screams power.:biggrin:
Something tells me I should be getting a nice pavement slick for this, :laugh:
P.s. I got me a radar gun but, it only reads up to 100mph
bikebudy
Slow going, waiting on parts. Repair 440 twin carb, repair 440 single carb, etc.
440 twin carb
440 single carb
Bike in a Box, :laugh:
Got the Rear tire Centered ( no more off-set ) by changing the clutch to another one.
bikebudy
I'd really like to ride that thing...prolly wheelie the whole 1/4 mile!!:thumbsup:
LOL, I sure hope not, hahaha.. A few feet I could live with :thumbsup:
The plan is to try it all first and see if its going to need a wheelie bar?
It may need a lot better rubber than I have on it now ?
Am I going to spin the rim off the Tire bead?
Same goes for a Parachute, do I need one ?
All I know is it will not happen this year, time is running out.
So, Build the frame, build it well and make sure the drive train is balanced.
I know a shop that does High Speed balancing of the wheels while still on the Vehicle . So I'll get the front done.
An then the rear with the clutch, brake disc and wheel all attached and balanced as one unit.
Safety, safety - safety..
I've had high speed crashes, an know they are not much fun.
I'll do everything in my knowledge to make the bike safe.
bikebudy
Well, I'm waiting on the last of the parts to come in.
The Engine is rebuilt, put back into the Snowmobile for the winter. May as well have some snow fun, LOL
Been out on its first test run, Starts and Runs very healthy.
Need to upgrade my clutch spring, this one is to light for this engine.
On the long run, Pops the Skis off the ground an goes like a scared cat. Yee Haa
