Hey Guys,
I was on my way home from last week and was lucky enough to drive by as a older gentlemen was walking out an old mini bike to the curb. Quickly I pulled over and asked if it happened to be going in the trash, he smiled and told me it was my lucky day. With a pop of the trunk a shake of a hand I was on my way back home. The next day i put air in the tires checked for spark filled with gas and that puppy for an hour haveing to manually work the throttle by hand it was still a blast. The motor still has plenty of life in it (no compression test was done but the butt dyno was happy enough). So....
Here's what I know or think I do about it:
I believe it to be a Cat 400x
Bought in '69 or '70 as a X mas gift(what i was told by PO)
Motor plate # 9007156
72t rear sprocket which acts as a fiction brake
manual actuated disc brake caliper mounted to a tab on the left side lower frame rail.
Dual rear shocks with a singular front spring attached between the frame and head set bolt.
Powered by an old briggs not sure on hp or model number
Needs headset repaired as it fell apart when I unbolted it
That's about all I know for now I'll post pictures of everything tomorrow Everything is apart now as I was soo excited about it I already stripped everything everything down blasted and painted the frame and motor.:grind::laugh:. It looked ruff. Please any input is welcome especially if you know how to decode that motor plate #9007156. Thanks
