hi all im new to this minibike stuff i have a older baja warrior jd 5.5 and i pulled itout of storage and got it running again and it ran good but did notice a lil bog in throttle about midway so i tore the carb out and freshened it up and then pulled the head off and did a mild port/clean up job on it and put it all back together and now she wont start i did have to loosen the exhuast rocker arm to get the the rod on that side out since i got lazy and tried to do this with the motor still in the frame and when i put it back together it felt like there was no compression so i pulled the head cover back off and loosened the exhuast rocker arm which was to tight since my torque wrench is mia and i tried to use the intake rocker as a reference for tightening and now it feels like theres compression again but still it wont start so i changed plugs rechecked the carb and everything is fine except for not being able to torque the exhuast to 17/7lbs is there anyone out there that can throw some ideas out for me to try? i was just looking for a lil more go and ive done the throttle stop removal and then this port otherwise the bike is stock
