I have only really painted three of my builds and have had this problem twice.
all the steel I by comes lightly oiled, but for the time it takes to build there is normally a little surface rust.
I stripped down Williams Trike and put a little body filler where needed, then gave the frame a light sand. Then used a scotch brith and thinners, then I wiped it with Laquer thinners then acetone using a clean rag.
The paint has adhered well on most of the frame, except in places aroundthen Engine mount. On my last build it was around the handle bars.
The first coat goes on fine, but the second coat literally flakes of the first coat in places. Its driving me mad.
Question time.
Is my surface prep enough?
I am using a white Luxor primer - not an etch primer - that I can only get in black - is this the right Paint
Do you think there could be oil that penetrated the surface of the metal?
Pics to show what I mean
Question time.
