Also watch E85 it is not the most user friendly...it can gum things up, and may need more maintaining than gas.
Depending on the mix.
Well, what I "was" going to say is Sounds like pump gas to me. And if you do end up with some insane, non-pull start compression ratio, you can mix race gas with pump gas, and there are on-line calculators to compute theoretical octane ratings.
No where in your data do I see possible numbers on final compression ratio.
You won't see any fuel savings in cost with E85. You'll end up burning more- in some tests I've seen a 20% increase to maintain the same AFR as with race gas.
There is also some data out there from folks having aluminum oxidation within their combustion chambers as a result of burning it. That guy saw a 3% power increase with the E85 on the dyno by the way.
