your Pic is alittle grainy but. here goes pointing out the obvious but where are the two upper piston rings? did you take them off for the photo? got a cigar use smoke to find the leaks old trick.. that scratch would clean up with steel wool/emery cloth I don't think that piston looks that bad mabye its the pic ? just looks like it got scratced when the ring draged across it when someone removed it. I have a RM250 it runs mint on an used ebay top end came with the used piston 50+ horse gas isn't gonna care. fuel, air, compression, spark your missing one... take some 180 and put a crosshatch on that piston go diagonal from two 45 deg angles for oil retention and put the rings on it correctly or get some new ones. put that head on insall the spark plug an try it before you put in the rockers. put a teaspoon of oil down the plug hole put plug back in and try it again.
