Here is a picture during the build:
The bike runs great except for the chain constantly falling off. I have tried pushing the engine on the frame to the front and back. I have replaced the washers and other hardware to ensure the engine does not move while in use. I have tried to make the chain as tight as possible, and still after use the chain will fall off. I have also ensured the the chain is straight and not crooked. I have come to the conclusion that the chain is shaking far too much and it simply falls off of the sprocket. This is the hardware I am using:
Clutch #35 12T 3/4" - Max Torque
Steel Sprocket - 66 Tooth / #35 Chain
#35 Chain (Standard) 10' - AZ4008
#35 Standard Chain
I need to fabricate some sort of tensioner so that the chain does not shake too much. Is there any suggestions you may have to solve this problem? My next move will be to upgrade the clutch/sprocket/chain to #41 but I really do not want to. Also, is this chain strong enough/qualified for this bike?
Thanks!
#35 Standard Chain
Thanks!
