So I bought a pair of Azusa forks online last year when my ARCO forks were not salvageable. The Azusa fork plates interfered with the ARCO frame so I bought a better set of plates from an OldMiniBikes member and set up the front end and welded up the forks. I was building a cruiser/pit bike at the time with very deliberately sized front/rear wheel and tire with a small front wheel/tire combo. The forks were never perfectly straight (my fault :doah: )and they always bugged me.
Fast forward to a year later, suddenly we're going drag racing and now that size wheel/tire isn't going to work anymore. The front of the bike is too high I kept thinking, but it actually looked kinda cool and I was trying to see if it would grow on me since I wasn't looking forward to cutting the forks apart again lmao!
If you look hard at this pic you can see it. At least I can lol. I wasn't helping matters by going with a 10" tall rear tire. Going up to an 11" helped but I found it a terrible time to find a high performance racing tire in 12" height so I had to stop there.
After battling a terrible high speed wobble, and going back and checking just how crooked these forks/front wheel actually were, I decided that it was time to stop expecting the bike to want to go straight when the front wheel is slightly off and the forks are slightly twisted plus way too high.
Time to bite the bullet and cut the forks apart. Started with cutoff wheel but most of it was done with hand files since I was wanting to reuse the forks.
After dropping the forks down 3 inches, now the handlebars were 3 inches too tall. Bars interfered with fuel tank, throttle/brake linkage doesn't reach lol.
So I cut the handlebars off completely and removed 3 inches and welded them back on.
Little bit of cleanup later, I now have the straight true forks that the bike should have had all along, as well as dropping the frame in front which really lowered the bike quite a bit. I think this is really going to help stability, on the limited runs I was able to make it really seems to help.
Thanks for reading!
