I posted in the vintage forum showing this bike I recently bought. its a 100% original 1979 manco streaker. It looks like hell though, Motor seemed to be locked up and looks like it had been sitting in a swamp (it was right near the banks of the ST. Johns river up in north FL) Even came complete with grass and twigs intertwined through it for were it had got parked and forgotten about long ago.
So I hit every bolt on it with PB blaster and let it sit a few days, Not sure what I was going to do with it. I started to take it apart the other day to see just how bad everything was. Its not so terrible really. The frame is heavily pitted, while it could be fixed, why? Its a streaker:doah: Once I got the wheels off, right to the blast cabinet they went. They did not clean up too bad actually. there is some pitting but not as bad as I thought there would be
Luckily The bolts came out for the sprocket and did not break the spacer, and I didn't even pull any threads out. All the hardware got blasted and cleaned and ready to be dolled up as well. The sprocket looked pretty bad even after media blasting, I hit it with some etching primer and will have to spray it silver.
The motor, Its an H30, cord was hanging half out the recoil, solid stuck or at least it felt that way. I started to pull the blower housing off and about 2 lbs of dirt and debris toppled out of it, complete with rusty water line on the flywheel:doah: cleaned that out and the motor moves, the recoil is all froze up by itself not really the motor:thumbsup: So I got it pulled and tore mostly apart to get a better idea of how bad it is, alot of rust (but not deep thankfully) on the shrouds but the block is pretty clean, carb operates smoothly, and looks low hours.
So what am I gonna do with that nasty frame? Make it worse:thumbsup: Today I went out with one of my wire brushes and started to scrape all the loose stuff off, then I painted it with aircraft stripper, broke out the pressure cleaner and started to blast away at it.
I'm just gonna leave it "raw". I still have a few Klingons of yellow, I would like to get it totally bare (with minimal work mind you :wink.
Since the motor looks good, is a correct mini bike motor etc.. its worth cleaning up no matter what, so I am going to do that. Not sure what I will do to it, I want to blast the tins and see how they come out, might leave them "raw" as well. Wheels are done, seat is perfect, chainguard is nice. Dunno if I will reuse the fenders, While I like to leave the bikes "original" those things are kinda gay! I'm on the fence about the handlebars as well, Maybe a set of tall chrome ones for it or something, or just leave it as is.
who knows, maybe a nice frame will pop up and I can just swap over and I can put this frame out of its misery finally:laugh:
