Thanks!!! this is the fun part of the project. It's always a treat working with finished minibike parts.
Here's before pictures of the frame set. The parts were de-greased and deep scratches were filed and sanded including any spatter from the factory welds.
The swing arm bushings were removed from the swing arm being that they would not hold up to the high temperatures of the curing ovens used for powder coating. The strut bushings were also removed from the triple tree as were the jackshaft and head bearings.
The swing arm bushings were removed by a machine shop, they pushed right out on a press. I was told that I could have used a C-Clamp, sockets and a lump hammer but decided to use this method to re-install the bushings.
Rupp Hustler Frame Set - Before
Ready for powder coating, finish will be high gloss black.
The seat pan was in sad shape, too much much time outside = mucho moisture and the seat foam acts like a wet sponge. There were some rust thru spots and uneven surface. the holes and rough spots were repaired with a brazing rod and later ground and sanded.
Rupp Hustler Seat Pan - Before
