ok mikuni it is order it tomorrow what jet for the low speed and what jet for the high speed ??? what good adjustments do these carbs have?
Your using a Utility engine right?
Don;t turn you nose up at a Utility carb.
Arc does not make this because they like to fleece people.
6878 ARC Carb. Adapter GX390 to GX200
DJ-3225 Carburetor, Honda GX390 HP
It also helps to have a big valve head to take full advantage of the carb.
NR racing sells an adjustable high side jet for easier tuning.
Ask around a few people around here prefer this carb because it is simple robust and once in tune stays there....
My single biggest beef with the PZ22 for example is it seems you need to constantly tinker with the and it spills fuel when the float needs tinkering.
