6hp
  1. C
    6hp Power Sport throttle connection
    I have a few questions regarding connecting throttle cable. There appears to be two locations where cable can be connected. One is at the side of motor and moves up/down vertically. Or it looks like it can be connected on the bottom part horizontally Which location should be used...
  2. M
    B&S 6hp - Starts then dies
    Hello, I'm new to the forum. I have a Craftsman weed cutter with a 6hp B&S Quantum engine. It was in storage for a long while. Before trying to restart it I drained the old fuel, removed and dismantled the carburetor, cleaned it and replaced some gaskets. Also replaced the throttle spring and...
  3. C
    Compatibility on Mitsubishi 6hp
    I have a 182cc mitsubishi GT600, 6.0 hp and I was wondering if this Predator Performance Air Filter with Adapter and Upgrade Jet would fit correctly, or does it have to be a 212cc 6.5hp to fit.
  4. dipper
    6hp Tec H60
    Tecumseh H60 6hp engine. 3/4" shaft. I do not know if it runs; it does spin freely. No fuel tank. Pretty sure it came off of a snowblower. Located in Rochester, NY $30 or best offer + shipping. Pics, click for larger version: Thanks
  5. capguncowboy
    Old Briggs 6HP engine -- flywheel removal?
    I picked up a BearKat this past summer and finally got around to working on it. It's actually in pretty good working order aside from a stuck valve, but I'm going to go ahead and rebuild it anyway. However, I can't seem to get the flywheel off -- or rather, I can't seem to figure out how it...
  6. dw1973
    New Honda GS190 6hp motor for sale
    Heavy duty Never ran new motor. Missing cap - cannot locate it. $200 firm + ship from 49279 Info: The GS190 offers the best of two worlds. Higher durability, with features like a cast iron cylinder liner and three-piece oil control. And the benefits of a lightweight, compact, quiet OHC...
  7. FloridaMiniBikes
    Big Block Tecumseh 6hp Monster (Craftsman)
    This is a beast from Hell! Not for the squemish. Please go back to the forum while you can. Pulled this off an overpowered retro lil mini bike back in the 90's. Powers up, but needs a carb and the usual goin over. Compression will kick you back into the last Windber ride......Twice. Starts...
  8. J
    Tecumseh 5 or 6hp motor
    I'm looking for a new or slightly used late model Tecumseh 5 or 6hp motor.
  9. Sinner70
    vintage Briggs 6hp engines
    Looking to sell these before they hit the scrap yard. Briggs and Stratton 6hp engines. No exhaust, carb, pull start. one has clutch. $10 each plus shipping. or if you need a part let me know. I'll strip them down if you need anything. PayPal preferred.
  10. Mr Big Mini
    118432-0060 6hp Vanguard, Horizontal
    hi guys! :scooter: just picked up three 6hp vanguard new in box, got a great deal on them at auction. is the B+S 6hp vanguard any good?
  11. mini one
    HH 60 OHV equals 6 HP no?
    So I picked up a Tecumseh Motor Sport OHV engine (silver) and was told it was a 4 HP but i'm thinking with the Model HH60 everything I see point to a 6hp. Right?
  12. R
    5hp with a carb from a 6hp?
    I have a 5hp engine and I wanted to know if a 6hp carb would work? I was gonna put a 16" inch straight pipe exhaust on it.
  13. Stangrcr1
    Briggs 6hp lighting coil
    My Yard Marvel Mountaineer Model 6-439 originally came with lights and a lighting coil. I have an era correct Briggs 6hp, but need the lighting coil and flywheel. Thanks!
  14. M
    Torque Converter, Stock warrior motor, Jackshaft
    I'm well and truly committed to my 15hp / 420cc build, so I'm trying to offload some of the old parts to get some change and some room in my garage. I have a GTC TC2 that I ran for a month before deciding that 45mph wasn't quite enough for me. It's still in beautiful shape. I bought it as...
  15. Beal
    6hp, bore out to 8hp?
    I have an oldish 6hpbriggs, I read somewhere on here that the 6hp block is the same as an 8hp block. So potentially, I could bore out the 6 to fit a 8hp piston? The head bolt pattern the same? Would It be worth it to do so? Or should I just get the 6hp running? Right now the 6 doesnt have...
  16. 6hp mitsubishi
    6hp mitsubishi
  17. minigonzabel
    project mini chopper
    Hello everybody this is my mini chopper that I am fixing up. Bought it from a guy not far from where I live for $35. I took seat and gas tank off to find the neck was cut out. Took accesories off that was not needed. Fixed and reinstalled the front hydraulic brake. Installed a headlight. My Dad...
  18. mini_bike_boy359
    Robin Subaru engine-overall Summary?
    Hello All, I have looked over the previous posts on the opinions about these engines, and I understand it this way: 1. They are generally reliable and well-performing. 2. After market ("hop up") parts are virtually non-existent. 3. Customer service/technical support is sub-standard. Is that...
  19. L
    Engine Testing Help
    I have a 6hp Tecumseh that came off of a Craftsman tractor which has an electric starter/generator. I was wondering does anybody know of any way to test this engine without using the electric starter and without spending the money on a recoil starter. Heres a photo ...
  20. A
    Check out my tecumseh (newb)
    MODS: NEW 15 INCH TIRES STRAIGHT PIPE OFF A BRIGGS SPECTRE FILTER+ADAPTER REBUILT CARB SMALL THINGS (VIDEO BEFORE STRAIGHT PIPE) YouTube - SPECTRE K&N GO KART
